Hobart tr-250-hf 4 rear Diodes near fan
  • Hobart tr-250-hf 4 rear Diodes near fan
    If any of these diodes are bad could that cause the machine to have low welding output ac & dc and?
    Could bad diodes also not all allow any function with the tig pedal and not engage the K1 relay at all?
    The output diodes will have no affect on the operation of K1. Make sure that if there is a preflow option that it is working, and that you have 24Vdc off CR1 control rectifier.
      Hello Keith I installed the new 4 diodes today and turned the machine on and tested for any power at the rectifier I do not show any power on any of the 4 pins.I looked the the manual you sent and traced all the wires but I am not sure what wire should have power at the rectifier
        Keith are there any power pin charts for this machine?
          Sorry, there is no tech manual for this unit that provides voltage or resistance tests.
