Extension cord for big distance.
  • Extension cord for big distance.
    First off hello, I'm new here.
    Now to the point. I live in an apartment that is roughly 150 ft off the street and have no off street parking. So all work I do on my vehicle, is basically done on the side of the road while I pray to all the gods in existence that my vehicle does not get tagged by a moronic driver while I'm under it.
    I have discovered some body rot and picked up a small welder to be able to patch it myself, for anyone wondering it's a cheapo "Amico tig-205". After doing some reading across forums and sites and all sorts of stuff, I have come to the conclusion that using an extension cord with ANY welder is not an Ideal set up, sadly I have no other choice. What I have come up with is get a 6ga 230v extension cable to cover to distance. For the life of me I can not find a 150ft 6ga cable, so anyone have any ideas?
    -Thanks for any help in advance.
    Most welder instruction manuals have a recommended length and wire gauge for extension cords in them... If yours does not, its probable not recommended... 150 Feet ???......
    From Amico page..
    Rated Input Power: AC 230V / 8.5KVA / 37 Amps & AC 115V / 4.8KVA / 42 Amps
    Cord will be much expensive... Rent a space that already has power installed that your welder requires...
    And as for working on car while on the street, not really good idea...Murphy's law states "anything that can go wrong, will go wrong"...
      What is the input amperage of your machine at the thicknesses you are welding? No way will it need a #6 extension cord. This is doable.
        Get 3 of these (often on sale, if you search) and you should have no problem, since you will only be drawing 33 amps at 200 amps or less, and voltage drop won't be too bad. You can always sell these later if you have no use for them.
        But, this machine sounds too good to be true, so let us know how it works! (60% duty cycle at 200amps for $269?).
        https://www.ebay.com/itm/Century-Wir...-/222780923426
          As for those cords, they look like they'd work, but I had a "DeWalt DXGN14000" 11,000 watt generator fall into my lap so I'm going to replace the engine on that an use it.
          As for how it welds I'm new to welding, a friend is a pipe welder on submarines, he's teaching me.
          From what he said it's pretty good , but we were only doing body panels at the time. It was arcing fast with no noticeable charge up time after pressing the button on the torch (if that matters), the torch itself is kinda bulky the handle diameter I'd compare to the handle of a pee-wee ball bat. If nothing else you can get a full set up for under $500, and it's good to learn with. I ended up grabbing a 60 cu. ft tank of Argon from airgas. A gas lens kit, argon regulator, filler, and some 1/16 red electrodes off amazon.
          I plan on fabing up a tire carrier strong enough for 34 's, getting frame strengtheners, and fabing up a wench bumper for the front. The strengtheners and the bumper will be 1/8" plate, and the rear axle will be trussed with 1/4" plate I'll let you know how it goes with that stuff.
          Other than that I thank everyone for all the responses.
            ... fabbing up a wench bumper for the front. ...
            Don't forget the winch, too. The wench gets you INTO trouble, the winch gets you OUT.
              Good one, MAC.
              A 240V 30A load on 150 feet of #8 should be right about 3% voltage drop.
                I tried putting wench on front bumper and all she did was scream at me.....
                  Both are more useful when tied up to something...
                    Much love for large, heavy duty extension cords on my part. I say fab or buy a cord because the extra reach is well worth it.
                    I assembled one when I rented and and have several now. Considering how much hassle it saves over a decade or more they easily pay for themselves. I bought the wire, plug and receptacles then assembled my own. Bonus for not using a molded cord is you can easily repair an assembled cord in the field. I started using dielectric "tuneup" grease (any auto store) on my outdoor cord connections and love the stuff. It's also dandy to exclude moisture from vehicle connectors. The old mechanics here may remember white lithium grease used for the same purpose.
                      I always use dielectric grease on any automotive or outdoor wiring saves a lot of headaches down the road...Many freak out that the grease is a insulative grease, but secret is having good mechanical connection under the grease, and with using grease it keeps oxygen and moisture out of mechanical connection thusly preventing corrosion... Works really well in vehicle light sockets...
