Hobart CT 300 ACDC
  • Hobart CT 300 ACDC
    I need to find a manual for a CT-300 ACDC. I have tried here but that model number won't come up.
    Newbe, relearning from high school45 years ago.
    It has a weld start button but I can't find anything to not weld except emergency off. Is there a way to leave the cooling fans on but be able to set the stick down to re-clamp work? Will it hurt to hit the emergency off button often?
    Please provide the SPEC# on the machine as well as the number on the white center panel.
    Keith
      Thank you
      SPEC# 5283D-1
      SERIAL # 83WS01610
      Are you looking for 300 SERIES from the white center panel?
      Warren.
        Check your email.
        Keith
          Thank you. Lots of learning now!
            Hi, I need a manual for that machine too. I have one exactly the same as the above. Here is the #SPEC and other data from my machine:
            SPEC: 5159
            SERIAL: 12RT-21775
            MODEL: CT-300
            Thank you
              Hi Any chance you could lead me to a manual??? CT300 100 series spec 5159C serial #12RT 64415 THANKS
