Dialarc HF
  • Dialarc HF
    I have a old dialarc HF it welds aluminum fine when I go to DC for steel it burns up the tungsten . I have tried pos and neg on setting . Has anyone know were to start looking .SN JB489086 Thank you .
    What is the no load voltage across the weld output in DC? Should be about 80.
    Keith
      What is you name?
      What is your quest?
      Sorry Keith, I couldn't resist.
        Dialarc
        Well I need to open up and get info so I can tell you . Thanks
          How to ck volts
          What do I do to ck output volts on this welder ? I don't want to fry the meter . Thanks Dan
            If you are checking the OCV, or no-load voltage, any cheap DC voltmeter can do it. Set it up to weld, but don't get close enough to start an arc. Measure the voltage from the electrode to the work. It should be the same, practically, as if you had no leads on the machine, and measured the voltage at the places where the leads are connected. Some machines may also have access to the conductive bits and let you measure there without taking the leads off. But the key is to have the machine on and set-up for welding, as if it was waiting for you to strike the arc.
              Thank you . Dan
