Just got a tig machine - L-tec 250HF Plus
  • Just got a tig machine - L-tec 250HF Plus
    Wasn't really looking but ended up with a tig welder. I have wanted to be able to weld aluminum for a long time but could never really afford a tig, and my mig is too little. Just at home hobby use. Anyway, looking through Craigslist I found this 1991 L-tec 250HF Plus. Did some horse trading and ended up with it for no out of pocket $. It came with the foot pedal but nothing else. Tried it out with stick leads so I knew at least that part of it works. Very clean unit. I have ordered a CK 17 torch for it.
    I am new to tig but have gas welded (including aluminum) and tend to catch on pretty quick. It will probably be a while (month or more) before I can get an argon bottle to really start learning. I have been watching lots of you tube videos and reading lots of "how to" web pages. Also found the manual download and have read through that several times. I also home brew so I will have some stainless work for the machine in the future as well.
    Pics
    Lincoln Pro Mig 175
    Miller Thunderbolt AC
    L-tec 250HF Plus tig
    Meco Cutmaster #45 O/A
    Ingersoll Rand 60 gal air compressor
    Jet 4x6 bandsaw
    Hendey 12x54 lathe
    Supermax YCM-16VS Mill
    G&E 14" Toolroom Universal Shaper
    Nice!
    I just parted out the forerunner a Linde.
    I'll be hanging onto some of the internals for a while yet.
    Scream if ya need anything!
    sigpicViceGrip
      Awesome. You don't happen to have the cover for the lead connections on the front do you? Of the water connection set up? I think I would like to have those 2 pieces if I can find them.
      Thanks,
      Patrick
      Lincoln Pro Mig 175
      Jet 4x6 bandsaw
      Hendey 12x54 lathe
        Dang No!
        The 305 had no cover, and the water works was the first thing I sold.
        Got water works off a DialArc & a 330 AB/P........
        It would need looking into If they could be made to fit.
        sigpicViceGrip
          Ok. I can make a cover easy enough, just thought I would check. Don't need a water set up right now but if it was headed for the trash thought I would grab it.
          Lincoln Pro Mig 175
          Jet 4x6 bandsaw
          Hendey 12x54 lathe
            Did some more horse trading with my LWS that my O/A tanks are from (55cu/ft O and 40 cu/ft A). They traded straight across for a 125 cu/ft Argon bottle. I had to pay the $60 for the fill but I was fine with that. It is rare that I use the O/A more than once a year, and I actually use propane anyway. Dad has several 330 oxygen bottles so I can borrow one when needed.
            Everything for the tig torch showed up yesterday. I can see this is going to be a steep learning curve! The welder seems to all work correctly, now I need to follow suit.
            Lincoln Pro Mig 175
            Jet 4x6 bandsaw
            Hendey 12x54 lathe
