AO Smith Tig welding issues
  • AO Smith Tig welding issues
    The issue I am having is it will not weld on AC. If you try to scratch start a arc it will just stick to the metal. In DC the HF start will not work, but if I scratch start it I can maintain a arc. The machine use to work fine till one day I was welding in AC and got the tungsten to close to the puddle and then shorted out. After that it would not maintain a arc. I inspected the gaps and its in spec. I am thinking a capacitor issue? Any thoughts. Thanks!
    Heres a pic that I found online that looks just like my welder
    Heres a pic of the inside of my welder
    Those Sangamo caps of that era***, used in the H.F. circuit,
    don't last forever.
    I've fould them ruptured wide open, but usually just leaking out
    an oily tar-like substance.
    *** a brown one in the lower pic.
    sigpicViceGrip
      Do you know the specs on those capacitors? Is there any upgrades?
        don't last forever.
        Do you know the specs on the capacitors? Any upgrades?
          I'm still having issues with this welder. Wanted to replace the caps but there's no specs on them
            I own the welder in your first picture. If I can get to it I will see if there is anything written on mine. This weekend will be busy but I will try.
            O/A
            DialArc 250p
            A-O Smith A3000
            Lincoln SP 135 w/gas
            And stuff I have lots of stuff.
              I would really appericaite it. If you could also take a pic of it too. It seems that some one in the past has added a extra cap as you can see in the pic above. THANKS!!!
