Cyber tig 300
  • Cyber tig 300
    WhenI mash pedal have to wait a little time for arc to work what is wrong
    Do you start to get gas right away? There may be a preflow setting turned up which will delay the HF arc start.
    Keith
      cybertig300
      yes I get gas rught away and have to wait for arc about 10 sec or longer
        On the left side of the control panel, is there a knob for PREFLOW? if so you can adjust this down to a shorter delay.
          cybertig300
          It acts like it is in pulse mode but I will try to a adjust when I use it again.To not use pulse mode what setting do you use preflow and post flow only every other knob on 0.Had it working a few times but sometime the knobs get moved by accident Thanks
            I turned the flow down to 1 or 1 1/2 and seemed to work betterThanks.One more question do you have to have the jumper plug to adjust the amps for arc welding on this machine if so where can I get one.Again Thanks
