Holder for TIG Torch 1
  • Holder for TIG Torch 1
    Alexander (AlexGo) showed a TIG torch holder on the following posting:
    http://www.hobartwelders.com/weldtal...ghlight=holder
    *This is shown below as TIG Torch Holder 1.
    *I modified this in SolidWorks to come up with my version of this design: TIG Torch Holder 2.
    *I decided that I didn’t like the filler rods sticking up from the pipe so I eliminated it, and added a place for filler rods on the bottom. This resulted in: TIG Torch Holder 3.
    *I built this design which is shown as: TIG Torch Holder 3a.
    (Continued on the next Thread)
    Don52
    Senior Member
    sigpic
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Holder for TIG Torch 2
    *I tried it out TIG Torch Holder 3a and found that my monster gas lens for welding stainless steel didn’t fit. I also didn’t like fitting the nozzle into the hole while welding so I came with: TIG Torch Holder 4. This design uses an aluminum angle instead of a hole to hold the torch.
    *I built this design which is shown as: TIG Torch Holder 4a. I just tried it out tonight and so far I like it.
    This is a work in process so any other ideas would be appreciated.
    sigpic
    Miller Thunderbolt
    Lincoln LE 31 MP
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
      Your holders are pretty fancy( you have too much time on your hands) I have been using this design for thirty years ...Easy and you can clamp it anywhere....
      Dynasty 350
      Hobart Beta Mig 200
      Twenty seven Hammers
      Three Crow Bars
      One English Springer Dog
      A Big Rock
        I like it. Your design would also work well for remote jobs (Not on the welding bench).
        sigpic
        Miller Thunderbolt
        Lincoln LE 31 MP
        16" DuAll Saw
        15" Drill Press
        20 Ton Arbor Press
        Bridgeport
          Tig Torch holders
          I am new to Tig welding with a new Dynasty 200dx and I need some projects other then the coupons to practice on, so when I came across this thread I got fired up! I like all three, however I like the later two as they allow the torch head to flex/move, whatever so not to break the nozzle or the backcaps (like mine has done several times ((I have a piece of flatbar sticking out from the bench with a hole in it, I put the torch in upside down) I think I will glue something up next time out to the shop.
          I was thinking an addition might be to epoxy a magnet on the bottom of the Aluminum setup so it could be attached to the welding table or clamped if on an Aluminum surface.
          Photos to follow!
          Thanks guys!
          Tim
            Go for it!
            sigpic
            Miller Thunderbolt
            Lincoln LE 31 MP
            16" DuAll Saw
            15" Drill Press
            20 Ton Arbor Press
            Bridgeport
              i like ie BC grab the handle and go. it's pretty much set in your hand when you go to pick it up . sorry the other design you preety much have to pick up with your fingers snd flip and twist to get ready to weld . but of coarse i have big hands to. all my friends at work say they thank god i'm not a proctoligist to
              lincoln pt225
              hack saw & a hammer
              oh & a shovel
                BC,
                I hope you don't have any copyright laws on yours. I'm going to make one like it. Thanks for the effort in postin the pic....
                Millermatic 210
                Dynasty 200DX
                Fisher CZ-5....CZ-3D
                Trek 5500
                1966 Amphicar
                  If you really want to get fancy, take B_C's design and weld or bolt it to one of those magnetic ground clamps with the on/off switch. That should work for just about anything except haning it from a tree.
                  BUY AMERICAN... THE JOB YOU SAVE MAY BE YOUR OWN!!!!!
                  Hobart Champion 16
                  Miller external secondary contactor
                  stick foot pedal
                  remote voltage control(homemade)
                  Hobart Portafeed 17(w AG-2000 control box)
                  Bernard Q350 mig gun
                  Hobart AG-2000 pull gun
                  Lincoln Hi-Freq k799(yes, I know it's red)
                  Weldcraft CS300 tig torch
                  Miller RFC-23A foot pedal
                  Thermal Dynamics Cutmaster 50
                  Victor 450/300 series torches
                  oodles of connecting cords
                  I can fix it, just pay me to replace it first
