I had a job come in yesterday and I'm not sure if I can do it just yet... Here's what I have:
-TA185 with CK17 torch
- cylinder head which was hogged out a wee bit too much by the customer who brought the head in. The damage is about 3/4" inside the exhaust port (from the exhaust manifold flange mounting area) and about 1/4"x1/4" in size. The port is approximately 1" wide (from damaged surface to other parallel surface of the port).
Now the plan is to back this area up via the coolant passage to allow for the same port shape but without the hole. Now I know my torch won't even come close to fitting inside...but what other torch alternative do most people use for a job like this? I'm assuming it would be watercooled (due to the small head size)? If that is the case I won't hesitate building a water cooled setup if need be, but I don't want to disregard any air cooled equivalents just yet.
Also the TA185 has 185 amps of output but since the damaged area is so thin and the backing plate to be used will be around 1/8" thick I don't think there should be much problems with penetration? Essentially I am using this job as a reason to obtain a small head torch or dive into the world of water cooling. Any advice would be greatly appreciated!!!
Here is a picture of the damaged port.
