I have an opportunity to pick up an old transformer type Syncrowave 250 for a reasonable price. The guy guarantees me it works. I am correct in assuming these were good machines and no problematic? He doesn't have the foot controller for it. Are those hard to come by on the used market?
Synchrowave 250
I'm guessing a good working SW-250 is worth about $1200.-$1500.
Maybe a little more with a cooler.
Research on Craigslist and Ebay closed auctions.
Good reliable machine but draws a lot of juice - 70A breaker ?
New Foot pedals here - $178.00
http://www.ssccontrols.com/homepage-...ngcontrols.htm
Good to see that a new foot pedal controller is still available. Thanks for the link. This machine should have way more capacity than I'd ever use in terms of amperage output. Its going to be a heavy son of a gun to load onto the trailer but should be worth the $500 I'm getting it for. I guess the market is moving towards more energy efficient, lighter, inverter technology. Can't wait to strike up an arc with it.
Tim,
The Syncrowave 250 is one of the best tig welders ever produced. Nearly bulletproof. As mentioned, they do require a lot of power (I'd recommend a 100A breaker. At max output they can pull up to about 96A).
I recently upgraded a Sync 250 that I purchased new in '96. Unit never gave me a bit of trouble. Went with a newer Sync 250 DX Tigrunner with the digital displays, built in cooler, etc. Added the pulser and am very impressed.
Miller service is second to none. Great people to deal with.
Good luck on your new welder. Let me know if you have any questions. Have a "little" time on the older Syncs.SundownIII
Syncrowave 250DX, Tigrunner
Dynasty 200 DX w/CM 3
MM 251 w/30 A SG
HH 187 Mig
Dialarc 250 w/HF 15-1
Hypertherm PM 1250 Plasma
Victor, Harris, and Smith O/A
Mil Mod 6370-21 Metal Cut Saw
Grizzly 6"x48" Belt Sander
Miller BWE and BWE Dig
Yup, at 500 or so I would go for it as long as you have power to run it.
Picked it up today. It will be a few days before I get a chance to wire it up. The points on the hf spark gap look corroded and dusty. I guess they sit next to the floor, so they probably pick up a lot of dust and moisture. The guy also had a Lincoln Magnum water cooling unit along with a broken torch that hey sold me for $75.00. Looks like I got myself one heck of a deal on some industrial grade equipment. It might be possible to fix the torch if parts are available. The hard plastic handle on the torch is smashed, revealing the gas and water line connectors. Hopefully I can figure out what brand it was.
Bad news. I'm going to find out how good the seller is for his word that he guantees it works. The machine unfortunately doesn't work. I opened it up, set the jumpers to the correct position for 230v. Flip it on, fan works, electrical outlets are alive. You try to weld on DC settings and it has an open circuit dc voltage of only 30 volts. Miserable as **** to maintain an arc. On AC setting, it has an open circuit voltage of 73 volts, but no current. You strike an arc, and its like you are rubbing two wires connected to a 9v transister battery. The machine is awefully corroded inside.
If I hook a welding rod across the two leads it runs full current through it no matter what the DC setting. Nothing on AC, but lots of current on DC. Glows the rod red hot even when set current to zero.
Might be a simple repair or an expensive one. 99% sure I have the voltage jumpers set right. There is a small label showing the jumper settings for 230 volts on an insulting panel inside the machine next to the line terminals and jumper.Last edited by Timinmb; 12-06-2008, 04:29 PM.
Originally posted by Hotfoot View Post...so you didn't get him to demo it before you handed him your cash??? I guess you'll find out what an honorable fellow he is...
Sounds almost like my Esab TIG's problems. It was a bad firing board on mine..which was repaired for around 200 clams. I wouldn't worry too much yet. Those units are well supported and like was already said, almost bullet proof. Take it to a welder doc and get it a check up. It may be a cheap fix.
One really good thing about those older Synchs is the support Miller has for them. My old Bobcat has maybe 40-50% parts support now because it is a 1988 unit. I had an opportunity to get a 1978 model Synch 250 last year. I was concerned about parts support, so I checked with my repair guy. He looked up the unit and found it still had 100% parts support.I didn't get the machine, but it was nice to find out the old ones are still supported like that.
Don
Go Spurs Go!!!!!!
Originally posted by Hotfoot View PostIs that a 560 volt three phase machine??? Might explain why it won't run on your one phase service...
