Thermal Arc customer service
  • Thermal Arc customer service
    I've read quite a few complaints in various threads here about the poor quality of Thermal Arc's customer service. I recently had an occasion to judge their customer service for myself. I have a TA ProWave 300GTSW AC/DC inverter welder. It's an older model that I purchased as a reconditioned unit 5 years ago and it's been running smoothly all that time. About a month ago, though, its flowmeter began showing an argon flow of 5 to 10 cfh anytime the welder was turned on. Since I promptly turn off my welder and the argon tank's valve in between welds, the argon leakage didn't concern me much. Two weeks ago, however, I phoned TA's customer service to ask how I might resolve this problem. A very cheerful sounding guy came on the line and explained to me that the gas solenoid valve probably had a speck of dirt that was keeping it from closing fully shut. He then went into some detail explaining how I should get to the valve and blow the valve out with compressed air. Several days later I opened the case and took off the gas solenoid valve. Looking into the end of its brass barrel I spotted a brown discoloration that appeared to be some kind of corrosion. I tried unsuccessfully with a tiny screwdriver to scrape this off and then blew it out with compressed air. After replacing the valve, I reconnected the welder and then turned it on. Again its argon flowmeter showed a constant 10 cfh flow. I turned off the welder and phoned TA's customer service number again. This time it was to inquire about the part number of the valve because I felt it probably needed to be replaced. The guy that came on the phone line was pleasant but didn't sound too cheerful. He listened to my tale of woe and then looked up the part number for the solenoid valve. After giving me the part number and the price of the part, he had no other suggestions to offer. I then thanked him for the information and hung up. So far I had encountered one cheery customer service rep and a second slightly morose rep. Both, however, attempted to be helpful.
    Before ordering the valve at a LWS that is a TA distributor and shelling out $150+ for it, I decided to see if I could find a service manual for my welder. Thermal Arc's website has a lot of operating manuals and some service manuals that can be downloaded from their site. The service manual for my 300GTSW was not one of them, however. But I did find it under their "Order literature" listing. I therefore sent an e-mail to the person in charge of ordering literature and asked the price of the manual. She responded the next day and surprised me by stating in her e-mail that the manual would be sent at no charge to me! About 4 or 5 days later I received the 95 page photocopied manual sent by first class postage. In my book that was first class service I received. From my recent experience I now feel that Thermal Arc's customer service is great. I have no complaints about it
    LarryL
    Brass valve body? If you can separate valve body from electrical parts and place valve body in vinegar then rinse with water and blow dry. Bye bye corrosion. Some designs have rubber disc that seals against orifice to stop flow. Flip disc to get new surface. Look on disc or what ever for dirt.
      thee manuals for the older machines are under the obsolete heading.
      i have the one for the 300GTSW in pdf if you need it
        Service manual
        chenry, thanks, I already have a copy of the operating manual, which I downloaded a few years ago from TA's website. I was asking TA's literature order manager for a service manual - since I was not able to find a pdf copy of that on their website. She promptly sent me a free copy of the 95 page service manual.
        LarryL
          hmmmmmmmmmmm
          wanna share
            Originally posted by chenry View Post
            hmmmmmmmmmmm
            wanna share
            chenry,
            What you need to do first is to contact the "Pricing Administrator" and ask the cost of having a service manual, 0-2515, for the TA ProWave300GTSW sent to you. This information may be found on this page of their website:
            She should respond to you, as she did to me, that a manual will be sent to you at no cost. If you have any problems going this route, then contact me.
            If it comes down to a need for it, I can scan my copy of the manual and send it to you as a pdf. However, I will have to find time to do that and the quality of the illustrations diminishes every time photocopies are made from a photocopy. The illustrations in my copy of the manual already are a little fuzzy.
            LarryL
