Champion 10,000 won’t strike an arc
  • Champion 10,000 won’t strike an arc
    I have a champion 10,000 and it won’t strike an arc. The generator doesn’t produce power either. Anyone have any advice
    We'll probably need more information than that to help any. When did it work last? Does the engine run? What do you get at the outlets?
      It ran last December. The outlets are dead the engine runs fine. I don’t know if this matters but the engine will not idle down it’s on high idle always. I assume it’s because there’s no power output
        I pulled the cover panel and the PC board has a part on it that’s fried. The part # is 203655. I can’t seem to find one that looks the same. My welders serial # is LB237482
          I would recommend taking this machine into a welding repair shop. Sometimes when a board fails it can indicate a problem that will cause the same failure if you just replace the board without checking into what caused the failure.
