Hobart T225 Stick Welder
  • Hobart T225 Stick Welder
    I was just wondering if anybody had a wiring diagram for an old Hobart T225 Stick Welder, I've got one in for repair and there is a lead floating around in the machine that doesn't seem to have a home. The fan comes on but there is no OCV.
    You need to list the serial #, model #, and all info on the machine spec plate.
      There is not too much to this welder, There are two wires that go to the main power switch, two wires that go to the fan and the rest are flat leads that go to the range switch all coming from the transformer.
        There is a flat lead just hanging out in the middle, I comes off the right hand side of the transformer but I cannot find anywhere the other end was attached to, nothing obvious, I would assume that it would go to the range switch somewhere but I see no empty spots. The lead is also intact, it didn't tear off wherever it was mounted, I assume that a fastener loosened up over time and fell out, that should make the location it came from pretty obvious.
        Northweldor: There is a serial number 2268G but this machine is pretty old, I believe that is predates SPEC numbers.
        I saw another post on here where one of the moderators sent somebody a wiring diagram and I tried to contact him through PM but it said that PM limit had been reached. Hobart Expert Keith
          Droo,
          Check your email.
            Originally posted by Hobart Expert Keith View Post
            Droo,
            Check your email.
            See, all good things happen to those who wait for Monday!
              What did you determine that the lead connected to, just curious.
                Expert Keith what did you determine the extra lead was for?
                  There is a flat lead just hanging out in the middle, I comes off the right hand side of the transformer but I cannot find anywhere the other end was attached to, nothing obvious, I would assume that it would go to the range switch somewhere but I see no empty spots. The lead is also intact, it didn't tear off wherever it was mounted, I assume that a fastener loosened up over time and fell out, that should make the location it came from pretty obvious...
                  Does it have any scrapes, or bare spots from where a fastener may have been? Perhaps this lead is for calibration at the factory, or used in a model that receives a different input voltage, and was never, in fact, connected in your machine. However, if this was the case, I would expect it to be protected from shorting out in same way, too.
                    The lead is for 208 volt input vs 230 volt, leads exchanged on the lower left power switch.
                      Droo, Are you sure about that serial number? I have a T225 Ser.# 2268G, that I bought new in 1968 in Bridgeport, CT.
                      Ed
                        My Hobart T225
                          I'm glad to see the pic. That brings back memories. That's the machine my dad first had when I was a kid. I remember a homemade full-wave rectifier for it that he had sitting on top. I didn't recognize it by just the model #.
                            when I started working at Hobart in 1964, I used to assemble and electrical test the T225 plus all the other static welders they sold.
