SM 210i Stinger & Ground Cable Sizes?
  • SM 210i Stinger & Ground Cable Sizes?
    What size are the leads on the SM 210i? There's Chinese writing on the insulation, and the number 16, but I have no idea what that means.
    Gregg
    Handler 210MVP
    Stickmate 210i
    Well I'm no expert, but if I had to guess, 16mm squared for cross section.
    https://muellergroup.net/technical/e...ble-stranding/
    Ok...I looked it up. But I did think mm, just not cross section squared for area.
    Maybe the better question is, are they sufficiently sized for amps and duty cycle?
      Why I asked is I wanted to change to a different ground clamp, one with the copper strap between the jaws.
      I changed the clamp on my 210MVP to this type and used a copper lug for 6 AWG, 3/8" Ring/Eye. I wanted to get the same ground clamp for my 210i so I know the ring/eye will be 3/8", but don't know the AWG for the copper lug.
      Gregg
      Handler 210MVP
      Stickmate 210i
        In case anyone else needs this info......it's 6 AWG, same as the 210MVP, but the insulation is quite a bit thicker on the 210i leads.
        I took the stinger apart and the actual wire diameter measured ~4.2mm.
        Gregg
        Handler 210MVP
        Stickmate 210i
