Simplified Arc
  • Simplified Arc
    Hello All;
    Just purchased a "Simplified" Arc Welder.
    Model: GHB 3183
    Serial No.: 12CW-5709 Spec 2335A
    Got the Ind. Chrysler 6 running, but no power to the welder or genny.
    Removed the bell and freed up the brushes. Now I can get a very small spark from the leads when I scratch the stinger by the ground but the gauges are still reading zero.
    Still have to clean the commentator but as this unit sat for a number of years I believe I need to"flash the field".
    Looking for a manual on this welder and when I go to the site this model isn't listed.
    Any info (field flashing procedure) and/or leads regarding this unit would be greatly appreciated.
    Though the engine is running smoothly it is my understanding it is a gas hog...oh well.
    Thanks in advance.
    Any chance of some photos.
      Hang tight help will pass by before long.
      vg
      btw ... comutator not commentator.
      plenty of good explantion on jumping the field on the net.
      sigpicViceGrip
        Have you freed up the brushes on the other end? special attention to the hard to reach bottom one.
