Electrode, electrode size, amperage and material thickness. (Arc)
  • Electrode, electrode size, amperage and material thickness. (Arc)
    Ok, semi quick question...
    Is there a chart showing the electrode & electrode size, plus the amperage range, and the recommended range of material to be welded.
    So, if I have a 3/32" 7018-1 I should be running 70-90 amps (give or take) what plate thicknesses are recommended?
    Is there a way to calculate this?
    Thanks, HW
    Sorta like this but with the reccomended thickness of plate for each. http://weldinggeniusbar.com/wp-conte...3/07/john4.jpg
    sigpic
    Eastwood MIG135, never fails to make me wonder.
    Lincoln idealarc 300/250: runs like it was made today. Looks like its seen some better days. Origin is Ashland lumber mill. Ready to go. Needs some new leads and a little specialty TLC.
    Harris oxyacetylene set, 20cf oxy and 10cf ace
    youtube channel :
    http://m.youtube.com/#/user/Hobbywelder617
    Yep, that info is readily available... they even have a phone app for it! Search the internet...
    https://itunes.apple.com/us/app/id452837820
    HH190
    Hypertherm 380
      Ok thanks.
      Certainly helpful if your not welding 'exotic' metals.
      sigpic
      youtube channel :
        Originally posted by Hobby welder View Post
        Ok thanks.
        They also have it for Android
          Call Miller at 866-931-9732. Order part number 043125. It'll cost you all of $4, and you'll get "slide chart" calculators for MIG, Stick and TIG. If you prefer metric dimensions, order part number 211600 instead. Or get 'em both if you want.
          Go here for some good pictures of what you'll get: http://store.aglevtech.net/timigsmmica.html
          Don't order from that site, though. Miller will send it all to you for $4 including S&H.
            a word of caution
            The electrode amp settings are close. The electrode size to plate thickness suggestion is for max deposition rate per minute or hour. Miller or Lincoln may even suggest running 5/32" rods on 1/8" plate! Plenty of penetration alright (and warpage). Maybe even 1/4" rods for 1/2" plate.
            fence and gate shop worker
            At home...
            Lincoln Power MIG 180....
