i have 2 of these with 20 to 80 hrs no power to front outlets or welder , what might it be i tested most of the back panel seems no power from wires coming out or in
champion 10000 welder and generator
the serial numbers for the 10000 champion la250125 the other is the same welder
there is a fuse in top left of front of unit. i through a current into. it it did come out the other side . this has a circuit board about 5 by 5 inches with 2 wire harresses connected to it with an owan motor if this helps
