I bought recently an older Lincoln AC-225-S with a code number 5683. It was partially dissembled, so after giving it a good cleaning, I started putting everything together. My question is about connecting the leads. I assume it doesn't matter which one goes where, since it's an AC unit. However, I am really stuck with connecting one of these leads - I just don't see any place I can attach it to. The other fits nicely on a plate just beneath the blade switch for amps. If anyone has access to the inside of this welder, I would greatly appreciate if you could look and kindly suggest where to attach the lead. Thanks! Andrey (Round Rock, TX)
Lincoln AC-225-S repair
AC-225-S Repair
Hello,
You can download a copy of the owner's manual for the AC-225-S via the Lincoln Electric website. Just be ready to put in a code & serial#.
www.lincolnelectric.com
Take Care,
John
225-S repair
Recently someone posted a pic of the inside of a AC-225-S on this forum or www.weldingweb.com. Do a forum search in the "Lincoln" forum you may find it there.
If I run across it, I will post it here.
John
Here is the picture of what I have. I am surprised that the owners of this machine, which is so popular in the United States, do not know what it has inside... I am originally from Russia, and can tell with confidence that the first thing someone in Russia does when he gets a new tool is remove the cover :-)
Originally posted by Jake_SS View PostWhy is that ally strap connected to the earth?
I can see the picture better here than on the other forum. I didnt notice that the strip of winding I talked about is connected to supply ground in your picture. That is not correct (as far as I know)
That stip of winding should go to the work lead (-)
Originally posted by grey View Post[...] the strip of winding I talked about is connected to supply ground in your picture. That is not correct (as far as I know)
Originally posted by kc5ngx View PostHow do you like your AC-225-S now that it is working? Try some 1/8" 6013 or 7018AC!
Glad to hear you were able to repair it,
John
AC-225-S Repair
Ugly Beads & Spatter?<grin> Sounds like some of my first attemps at welding with the AC-225-S!<grin> All kidding aside, I got better with time. The AC-225 will make a fine bead! Just watch your arc gap and travel speed. Also, I have found out that 7014 (Fleetweld 47) makes a nice bead with little splatter.
As far as the noisy fan, I have a Lincoln Idealarc 250 that had a noisy fan. The fan noise became quite over some time. I think the machine was in long term storage at some point. Also, It could be the fan bearings going south on ya.
Take Care & Have Fun,
John
