Anyone know here I where I can find out any info on a P & H A.C. Arc welder, model th-300? Was my father in laws and now I have it.
P & H Arc welder
Follow the link to a military manual that might be close to what you have.
If you could post a picture of your welder I might have more info available.
http://www.141.com/chevy/misc/p&h-dar-300-manual.pdf
Your welder might also be very similar to the Linde HD-300 / 200 welder which I also have a manual for. Like I mentioned above, a picture would sure help.
Brad________________________
Richmond, KY
Hobart BetaMig 200
Linde HDA-200 AC/DC Tig/Stick
Dayton Buzzbox
well guess that did not work, so I will try the links to the pictures
http://s427.photobucket.com/albums/p...nt=Unnamed.jpg
http://s427.photobucket.com/albums/p...t=Unnamed2.jpg
http://s427.photobucket.com/albums/p...t=Unnamed3.jpg
http://s427.photobucket.com/albums/p...t=Unnamed4.jpg
Originally posted by choprdoc View Postwell guess that did not work, so I will try the links to the pictures
The toggle on the left, with the indicator light above it, is the main power switch,...the toggle in the middle, I'm guessing is the remote/panel switch and it controls the outlet to the left of it. the rheostat on the top right, I believe is the arc control....the outlet with the corresponding toggle..haven't a clue...the outlet on the top left, I'm just guessing again, looks like 120v AC...but I'm not sure. I haven't used one in 40 years, so my recollection is a little fuzzy.The decay of internal parts would be a great concern to me. I'd be scared to fire it up, as is.
Originally posted by Rocky D View PostThe toggle on the left, with the indicator light above it, is the main power switch,...the toggle in the middle, I'm guessing is the remote/panel switch and it controls the outlet to the left of it. the rheostat on the top right, I believe is the arc control....the outlet with the corresponding toggle..haven't a clue...the outlet on the top left, I'm just guessing again, looks like 120v AC...but I'm not sure. I haven't used one in 40 years, so my recollection is a little fuzzy.The decay of internal parts would be a great concern to me. I'd be scared to fire it up, as is.
Originally posted by cope View PostWhere's your spirit of adventure! My cousin had a 1946 vintage 295 amp AC machine that ran as good as new, and it sat outdoors for the 1st 10 years of it's life before he built a cover for it.actually, truth be known, I'm livin on borrowed time, anyway...
Franz has one of these...here's what he says:
Power
Local/remote toggle
AC DC DCRP- big pointer
HF constant off start
Fine current = percentage of range
RANGE
Phase shift
Balance (I think) ain't looked at mine in a while and there is a foot of snow between me and it.
BTW, just about every one of the green monsters is an individual since they built them to customer spec. That one may be AC only, can't see the dang picture clear enough.
Originally posted by Rocky D View PostThat one may be AC only, can't see the dang picture clear enough.
Hobart HH 125EZ
To Power up, or Not?
Greetings. I just inherited a DAR-200-HFGW from my dad. It hasn't been used in about 10 years, but looks very similar to yours. I'm about to fire it up, so if you don't hear from me again Rocky D was correct and its a bad idea. I can't get the posted link to the *.pdf manual to work, fear it has disappeared. However I do have hard copy of some sort of operators manual, and can probably scan a few of the pages of interest. Try sending me a direct email.
Long ago I did use it. In case you don't know I believe the high frequency feature made it a lot easier to start the arc. When turned on you didn't have to actually touch the work piece to get an arc going, the HF would jump start it.
On and off are obvious, I think auto meant it turned the HF off when there was current flow, ie while there was already an arc.
Will
