What do you set Arc control at when welding with smaw (stick)? I'm having some challenges with my new to me Syncrowave 250 and I see the manual says to set it to zero for tig or off. But what is a reasonable setting for stick welding? I'm running into a weird effect with 7018 electrode positive. So I tried 6011 and it does a similar thing. The arc starts and burns out, then starts and burns out, over and over again repeating the same cycle. What gives?
Syncrowave 250 - "Arc control"
Originally posted by Timinmb View PostThe arc starts and burns out, then starts and burns out, over and over again repeating the same cycle. What gives?Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Hobart HH 125EZ
I see from the manual its also called "Dig". Apparently it increase amperage as you close the arc gap. That might be what's producing the unexpected effect. I'll have to play around with this setting. Its like I touch the electrode to the work and it gets a burst of energy, burns it back, amperage drops off and the arc extinguised, and I repeat this cycle over and over again. I'd better make sure I try it at zero as that may better approximate my other stick welder which I have no problem with (as it has no settings other than amperage ).
