what do u think of these welds?
  • what do u think of these welds?
    i just got into a welding class trying to get my certs in L.A county first is some 7024 2nd is 7018 3/32 horizontal and 3rd is some 6010 what do u think of them and do you have any advice i just got on this board and love it so much info thanks guys
    rob
    http://farm4.static.flickr.com/3054/...7159cf28_o.jpg
    http://farm4.static.flickr.com/3147/...7728413d_o.jpg
    http://farm4.static.flickr.com/3208/...0ea87849_o.jpg
    cky450mm
    Member
    over 100 views and now 1 opinion come on now
      THey look pretty good...
      A little bit of extra spatter, but thats ok.
      Maybe the heat was a little low on #2
      The Welder Shop: Welder Reviews and Great Deals On Hobart, Miller and Lincoln Welders.
      The Welding Bible: Handbook on how to arc and gas weld.
        About how long was your arc, there is alot of exes spatter.
        Old Airco 180 amp A.C.
          first pic (7024): left end top bead no fusion into the vert plate. Too much spatter. Try aiming a little more to the vert plate-- maybe 10 to 15 degrees-- to get better fusion there (gravity will pull the bead down) and keep the arc TIGHT to control the spatter. The flux should be just about touching. You can even drag it.
          Second (7018): pretty good for a first try. Watch your speed. A bit fast in spots.
          Third (6010): You need to work on controlling you speed and following line, but much of it look good, with fairly even spacing on the disms and good fusion. The not so good spots look like you tried to speed up. Spatter control comes with practice, but '10 and '11 do spatter a bit. Try adjusting the dig (arc force; voltage) control and see how it changes.
            thanks for the replys im i was reading about controling the arc force online so im going to try to use what u guys said and what i read when i go back today thanks again for the help maybe get them looking a little better today
              To help you keep your beads even in width, make lines with soapstone. Soon it will be second nature.
                will do thank you for that pointer
                  And make sure you Eat Some GRITS before welding.....
                  Dynasty 350
                  Hobart Beta Mig 200
                  Twenty seven Hammers
                  Three Crow Bars
                  One English Springer Dog
                  A Big Rock
