I just saw mentioned in a post the possible innaccurcay of dials on stick welders. Has anyone tried a clamp-on amp meter to get a better idea of the accuracy? Just a thought, if it would work?
Amps Reading Accuracy
Unless you're developing a WPS or something similar it's just mental masturbation. You set it where it works for the rod and the material, and how many actual amps it's making is moot.
Other processes where you're trying to transition into different transfer modes, etc. it may be useful to know.Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Hobart HH 125EZ
I'm glad to hear that the clamp on meters work. I'm a hobby welder and don't use stick often enough to remember the sweet spot settings. Maybe I'll check just for dial accuracy. I thought it might be useful as everyone on here refers to amperage settings when talking stick diameters? Oh well. Uncrichie.
Originally posted by Zrexxer View PostYou set it where it works for the rod and the material, and how many actual amps it's making is moot.
The only time I worry about it at all is when it is a requirement to meet a WPS. The only machine I routinely use for stick that has any indicator at all is my Max150, and the mrkings are at best approximate. Every other machine in the shops I work in has a 1-10 dial or no marks at all (the lincoln SA USED to have marks, but the original adjuster became unreadable years ago).
If it really matters to you, keep in mind that the same knob position won't always give the same current, unless the machine has the electronics to insure that it does. For example: a synchrowave will be real close, a tombstone will be at best in the ballpark.
If you need to measure the current, a DC-capable (hall effect type... measures the magnetic field directly) clamp on meter is the tool. Many clamp on meters are AC only (inductive pickup... th measurement is made using a wound transformer coil).I may not be good looking, but I make up for it with my dazzling lack of personality
I am with most other guys, dont really care what the numbers on the dial say.
