Miller/Smith Series 30 (31-50-320) Regulator, Need Hose Connector
  • Miller/Smith Series 30 (31-50-320) Regulator, Need Hose Connector
    I'm currently using the Hobart regulator (CGA-580) that came with my 210MVP on a CO2 bottle. I bought the regulator in the title, from Cyberweld, so I could move the original Hobart regulator to another bottle and put this new one on my CO2 bottle.
    The ad for the Series 30 regulator says: Outlet Connection 5/8-18 RH Internal
    Since the Series 30 outlet connector is 5/8-18 Internal, I assume I need a 5/8" male with a 1/4" barb connector to connect the gas hose from my210MVP to this regulator.
    I've looked everywhere and can't find that size......any help is appreciated.
    Umm... You could go this way... All parts are Western Enterprise welding gas fittings....
    http://westernenterprises.com/enterp...-arc-fittings/
    Click image for larger version  Name:	regulator fix.jpg Views:	1 Size:	54.7 KB ID:	704527
      OR, should I just get another hose with screw in fittings on each end?
        For ~$10 I just ordered a 6' hose with 5/8" screw in connectors on each end
