Straight Argon for welding SS?
  • Straight Argon for welding SS?
    My welder is currently setup for aluminum welding with 100% argon. Can I use the straight argon with SS welding wire to weld SS?
    I need to weld a stainless steel bung to an exhaust manifold.
    What process you planning to use?
    If it's GTAW (Tig) you're good to go with straight argon.
    If it's GMAW (Mig) you're better served with a Tri-mix. SS and straight argon do not do well in the GMAW process.
    SundownIII
    Syncrowave 250DX, Tigrunner
    Dynasty 200 DX w/CM 3
    MM 251 w/30 A SG
    HH 187 Mig
    Dialarc 250 w/HF 15-1
    Hypertherm PM 1250 Plasma
    Victor, Harris, and Smith O/A
    Mil Mod 6370-21 Metal Cut Saw
    Grizzly 6"x48" Belt Sander
    Miller BWE and BWE Dig
      I agree 100% argon works for TIG. That is all we use at work and it works great.
      For MIG, 98% argon 2% oxygen will work good, but it is a hot process. You won't get a stable arc with 100% argon though.
        you are good to go with 100% argon on ss with tig
          I am using a MIG welder.
            If the straight argon and SS wire wont work, can I just use flux-core wire to weld the stainless bung to the manifold?
            BTW, the exhaust manifold is cast iron.
