When I shut my plasma cutter off in the torch area it is still leaking air until I disconnect from the air compressor. Any ideas what I need to look for in why it's doing that? It did cut a for a few minutes in the beginning and then stopped prior to that.
hobart 27i Plasma cutter
Same here, I don't know how can I solve it. I will be thankful to you if you provide me with the answer. I am waiting for your reply and till then I gonna visit https://casinosters.com/betfred-casino/ here because I want to play those games through which I can make a lot of money and that website helps me by providing those website links where I can find real money gaming sites easily.Last edited by ClairCurrie; 02-21-2023, 11:02 PM.
A wild guess is the air control solenoid valve is slightly sticking open or has crud in it not allowing it to totally seal OFF when shutting down.... Probably trying to remove valve and disassemble might clean up issue or maybe replacing solenoid valve...."Fear The Government That Wants To Take Your Guns" - Thomas Jefferson..
