Hobart 250ci problem.
  • Hobart 250ci problem.
    I have had this unit sense 2012 bought brand new.
    The problem is I started to use it & the cup light came on this week, never happen before. I use 3-4 times a year. So I went to manual it said to replace the tip & electrode so I did. I tested it worked. The next day I went to use it, it started then light came back on shut it off to rest It think it started working then nothing. I said the heck with it & just put everything up. Im lost.
    I have read somewhere that it could be a bad torch is this true? You can email if you like. [email protected].
    Jeff
    Could be a bad cup switch, check your cup and make sure it fully tightens and depresses the microswitch.
      Ok will do. Ill keep you posted.
        Hi Jeff,
        Did you ever find a solution to the problem you were having with your Hobart 250ci plasma torch? Sounds like we might be experiencing a similar problem.
        LeeAnn
