Plasma cutting machine
  • Plasma cutting machine
    Hello...
    I have a small business of automotive repair.But my old plasma machine is going to be bad.Now,I am searching Plasma cutting machine for my business.
    So,Any recommendation for plasma machine.
    Thank You in advance.
    Purchase the most expensive one you can afford. Go with a brand name. You implied you have a business to run so that means you will be using it more often than the hobby shop user. If I ever purchase another one it will be one that cuts thru 1" at least. My Hobart air-force is a very good piece of equipment, but there are times I need to cut thru thicker material, such as 3/8 or greater. Thats when I reach for the O/A bottles. Effective yes, but slower and messier. Plasma is quicker, and cleaner.
      You are very correct but the original post wreaks of spam to me as does the reply.
      Thanks for reading/listening.
        I reported both posts this morning. Surprised they are still here. Obvious spam.
          Welcome...
          Lincoln A/C 225
          Everlast PA 200
              Try your plasma on 3-6" material and see how quick and clean it is!
                As a general rule, plasma is faster at cutting material under 1/2" thick. Even with a larger amp plasma, oxy acetylene is still faster (and cleaner in the right hands) on thicker material.
                Lincoln Idealarc 250
                Miller Bobcat 250
                Thermal arc Hefty 2 feeder
                Thermal Dynamics Cusmaster 52
                Torchmate CNC Table
                  Oxy-acetylene... pic from the old Doxford shipyard. (more here: http://www.shipsnostalgia.com/guides...xford_and_Sons)
                  Some were thicker:
                    [ATTACH=CONFIG]38823[/ATTACH]
                    Some were thicker:
                    [ATTACH=CONFIG]38824[/ATTACH]
                    Great pics of a past we should remember! Thanks for the link.
