power on but short cut
  • power on but short cut
    I have a 250ci and when i cut it runs for 2 sec and then stops cutting ( flame out) without a fault light and the compressor still runs for the correct time, I dont have a problem with the cup light, if i loosen the cup the light will come on and stop all operation. if i let go then squeeze the trigger it will cut as many times as i do this, and flame out every 2 sec, the only thing is that when this happens the green power light flashes and then when I cut again it will stop flashing till the flame goes out again 2 sec latter. it has a good ground and clean consumables, any help would be much appreciated.
