Cutting/gouging welds in thick steel plate
  • Cutting/gouging welds in thick steel plate
    Hi guys!
    I have some thick steel plate that has been welded(t-joints). I was thinking of cutting the weld out and using the metal to build something else. Most of the plate is 1/2" thick. Would a plasma cutter offer decent results? I thought about going at the welds with an angle grinder but that would be pretty time consuming! I do not currently own a plasma cutter but have wanted one for a while. This may be a good reason to get one!
    Thanks,
    Steve
    A plasma cutter that has gouging nozzles would work well for this application. Using a cutting nozzle likely would not work well. The Hypertherm 45 amp and larger systems all have excellent gouging capability.
    Jim Colt
    Originally posted by Steve1795 View Post
    Hi guys!
    Thanks,
    Steve
      The Hypertherm 45 is a little more than I wanted to spend. Do you think a slightly less powerful machine would have the ability to gouge without being underpowered? The hobart airforce 500, miller xtreme 375, and the hypertherm powermax 30 were the ones I was looking at. I dont want to get one if it wont be able to cut these welds. I would like a larger machine but I can't really justify the expense right now.
      Thanks!
      Steve
        If you have a CC power source of sufficient nads along with a decent air compressor you could carbon gouge it. Pick up the torch for cheap.
        Be clear on the safety procedures before doing it so you don't burn down the neighborhood.. as the process does make some impressive fireworks.
        Mike
          I second the carbon arc, great way to blow that weld off.
          Miller dynasty 350
          Miller syncrowave 250
          Miller deltaweld 450
          Miller cp-300
            I have a good air compressor but no cc power source.
            Thanks for all the good feedback!
              Just go rent a plasma cutter from an equipment rental place for a day and be done with it. Rent a Hypertherm 45 or 65 with the gouging nozzle/tips and all is well. Why buy. You probably can't afford the price of admission and don't want to.
              Black Swamp Rentals (Nationwide) rents Hypertherm by the day or longer. My buddy rented one to cut up an aluminum bulk tanker to scrap.
              There are alternatives to buying.
              carbon arc gouging works but is very dirty and slow.
              www.flipmeisters.com
              Harris OA
              sigpic
                Thanks for the tip. I bought a Hypertherm 45 this morning. I guess I was able to 'afford the price of admission' !
                Steve
                  Carbon arc gouging is dirty, loud, but NOT SLOW! It actually has a higher metal removal rate than plasma.
                  Hypertherm has some of the best quality and affordable equipment available. Your "buddy" made rental pay on a oneshot job, but has no plasma cutter, and wasted the rental money on a job that probably would have paid for the plasma cutter, and still made a profit. The OP, wisely, did not take your advice.
                    He's not stupid... He borrows mine now. (I have a Hypertherm 65).
                    For one job, rent to try and then buy.
                    Harris OA
                    sigpic
