Airforce 750
  • Airforce 750
Name:	Plazma cutter1.jpg
ID:	667814Click image for larger version
Name:	Plazma cutter2.jpg
    I just bought this for 50 bucks. The pilot arc starts up but dies instantly, but the cutting arc does cut as long as it is in contact with the materiel. if anyone has ideas to as to how to correct this it would be welcomed.
    Welcome to the forum.
    Lincoln A/C 225
    Everlast PA 200
      Originally posted by rdoss1970 View Post
      [ATTACH]35798[/ATTACH][ATTACH]35797[/ATTACH]
      This is normal operation for this machine, and the pilot arc should be switched to the "expanded metal" position only when cutting same material. If you run the pilot arc continuously, you will decrease the life of your consumables.
      You got a great bargain! Now, download the manual and learn to use it!
