oxy/ lpg cutting torch
  • oxy/ lpg cutting torch
    hi, i am new to this site & to gas cutting torches i have looked & cant find my answer.
    i am looking to get a victor medalist 250 lpg med. duty cutting kit & i would like to run the hose length out to a max of 50 ft.
    can i go that far &, what size hose do i need & if i cant got that far what is the max length & hose size, the max steel i will be cutting is 1 in. at the very most 2 in..
    thank you, for your help......... clod
    You probably want larger diameter hose...
    Be aware the 250 set comes with 3/16 x 25 ft grade "R" hose (Acetylene only) ...
    Better hose option would be a 50 foot 3/8 hose and Grade "T" (all fuels including LPG), Grade "R" hose is for Acetylene only.
    https://www.zoro.com/radnor-twin-wel...47/i/G8576181/
    If not 3/8 maybe 1/4 inch...
    https://www.zoro.com/continental-hos...07/i/G0628476/
      50' isn't all that far. I'm sure I can find a chart somewhere, and it may or may not agree, but a 1/4" Grade T hose will probably do the job fine.
        than you
        now need to look for flash back arrestors for the torch, will any brand work that fits torch & hose or must be vctor. ??
        then cutting tips, same question for the tips. ???
        thanks, again
        what else do you suggest i get. ??
        i have two plasma cutters so i have that safety gear..
          Check torch specs many of newer torches have them (flash back arrestors) built in....
          https://www.esabna.com/us/en/product...50-classic.cfm
          LPG (propane) uses a different tip than acetylene, "but" you may get buy with acetylene tips...Usually orifices are bigger for propane tips.. ...
            I use 100 ft on them for years.
              But what diameter.... If he just adds another 25 feet of 3/16 (which comes with the set) isn't flow going to be come effected... I really think with the longer the distance the larger the diameter of the hose needs to be to not adversely effect flow....
                And the flow needed for cutting a specific thickness is part of the math, too. I didn't look for a chart, but it can be found with a bit of Googling.
                  I use 1 /4. I have added the smaller one as a whip. I need to fet new.
