Victor Edge Series 300 Acetylene Regulator Noise
  • ClaytonDornsife
    Thanks Northweldor and Dale M., I'll be bring the regulator in, appreciate the information.
    Originally posted by ClaytonDornsife View Post
    Hi,
    I was wondering if anyone else has experienced (or has an explanation) for a disconcerting sound that emits from my Victor Edge Series 300 Acetylene regulator. When I'm cutting or welding, the acetylene regulator makes a whining sound, somewhat similar to the sound when you bleed the rig after finishing. I've checked for leaks, and there is no drop in pressure when I'm using it, so I think it's something minor with the diaphragm. It's been doing this since I got it without any other issues, but I'm reviewing my safety procedures, and curious if others have this problem.
    Apparently Victor provides a lifetime guarantee, but the people at my local Robert's Oxygen are not always helpful, so I thought I'd get some feedback before I go in.
    I'm an amateur, so thanks for any help.
    All regulators vibrate at a constant frequency when gas is flowing, but in normal operation, both of a pair will sound about the same, If the sound is radically different from the oxygen regulator, then I would consider return or repair.
    Below is a diagram showing the diaphragm which is the source of the vibration (newer models still use the same principle, but diaphragm is likely metal). Click image for larger version
    Probably vibration of diaphragm..... IF LWS no help contact Victor/ESAB directly...
    https://www.esabna.com/us/en/product...ctor/index.cfm
    https://www.esabna.com/us/en/support...nformation.cfm
    Had really good response with these people when I replaced diaphragms in my Victor setup...
    https://www.regulatortorchrepair.com/
  • Victor Edge Series 300 Acetylene Regulator Noise
    Hi,
