New cutting torch clog
  • New cutting torch clog
    I purchased a new cutting torch at auction and something has to be clogging the barrel, because the gas and oxygen are not coming thru it to the cutting torch.
    Well...I'm sure the possibility exists you got a broken one. I doubt it, but the possibility does exist. I have to assume you have things set up properly and regulators adjusted? With out more to go on, check your tip.
      This is going to sound real elemental (not knowing your experience level), do you have pressure on output of regulators, and with cutting head off and welding tip on do you have flow?
        The quality of the question will determine the quality of the answer. I'll wait.
