My workplace just issued a recall to the trades on Worthington MAPP-Pro portable cylinders. Apparently the valve may not reseal when you disconnect the torch, allowing the gas to leak out and create a hazardous situation.
The recall is as follows:
Sold at: Various plumbing/HVAC distributors, Home Depot, Lowes and Ace Hardware Stores nationwide and in Canada from October 2004 through January 2012 for about $7 to 13 for cylinders and $45 to 75 for the torch kits.
Remedy:
Unused cylinders: If the cylinder has never been connected to a torch or other device, do not use cylinder. Return cylinder to store where it was purchased for exchange or full refund.
Partially-used cylinder currently connected to torch or other device: Do not disconnect torch or other device. Take outdoors and ignite the torch and burn off entire contents* of the cylinder. Disconnect the torch from empty cylinder and dispose of empty cylinder per cylinder label instructions or return it to store where it was purchased for exchange or a full refund.
Partially-used cylinder NOT connected to a torch or other device now: Take cylinder outdoors. Leak test top of the cylinder with soapy water. If bubbles develop, attach the torch. Ignite the torch and burn off entire contents* of the cylinder. Remove the torch from empty cylinder and dispose of empty cylinder per cylinder label instructions or return it to the store where it was purchased for exchange or a full refund. If no bubbles develop, do not use cylinder. Return it to the store where it was purchased for exchange or a full refund.
Remedy:
