I was wondering how everyone else stores their regulators when not in use, I have mine hanging above the tanks. Is leaving the tank to reg connector uncovered an invitation to spiders building nests?
how do you store your gauges?
I collect plastic caps. Pipe thread shipping caps, JIC fitting caps, flare fitting caps (from a friend that does commercial HVAC... most every piece of equipment comes with these in that business), and so on. When I pull a regulator or hose, caps go on. Even in the case (or maybe especially in the case) for the portable outfit.
Spiders and insects are a concern, but grinding dust and other debris is much more of a concern.I may not be good looking, but I make up for it with my dazzling lack of personality
You can also buy metal screw on caps.
I have habit of very short cracking of cylinder valve to blow out crud before attaching regulator.
This is from charging scuba tanks that could have water in valve and cause pin holes if not blown out of valve before charging. A buddy's scuba regulator had much less internal corrosion problem because he always rinsed his regulator while attached to valve then blew cap dry before installing on regulator.
My regulators stay connected to the tanks also. I could cover them when they're not in use, but, I use my welding outfits often enough that the spiders don't have much of a chance to spin their webs around them. Woe to the spiders that attempt to do that!
LarryL
I throw them in the gang box with the torch, and the hose"Weld It And You Won't Be Screwed"
My dad gave me a pair of victor 450 series and the fits had been covered with elec. tape for years. Makes for a sticky mess but done the job. I would try to find some plastic caps much less mess..Hobart 140 Victor O/A 450series Milwaukee sawzall Drill press Chinese sandblaster
Dewalt chop saw
hmm. i have a few plastic caps i could sell youno but did you get the regulators new? when i got mine they came with plastic caps on them.
I would never, ever, under any circumstances, put any tape, or anything other or else that might leave a residue, of any kind, on an oxygen fitting.*** Disclaimer ***
Likewise, I leave my shop setup installed unless changing cylinders. I do have extras though and I keep them in a drawer with plastic caps on the openings.Scott
Miller XMT 350 CC/CV
Miller 22 A wirefeeder w/Bernard 400A Q-gun
Miller 30A Spoolmatic/WC-24 Weld Control
Hypertherm Powermax 30
CK 210 torch / WP-18 torch
Victor, Harris O/A cart
4"x6" Enco bandsaw on raised cart
Dewalt Chop, etc.
