Looking to round off the edges of 3/4" steel on my tractor loader arms. Will an Oxy Acetylene torch be enough? What size nozzles do I need? Any other things I need to think about as a newbie? Thank you. Paul Pec
3/4 inch
Welcome to the group Paul. I'm not totally understanding what you are needing to do. Are you talking about cutting 3/4" steel flat bar to make the end round? If so, just about any O/A torch will do that. Just be sure to never run the acetylene over 15 psi MAX. The oxygen isn't as limited. 40-50 psi will probably do anything you need. Please clarify what you intend to do and we'll jump in and help.Jim
Miller MM 210
Miller Dialarc 250P
Airco 225 engine driven
Victor O/A
The tip of the inner cone of the flame shall be about 1/8" above the metal.
Take a look at the brief description of the procedure here: http://www.calaged.org/ResourceFiles...uster/2256.txt (chapters C and D may be of interest to you)Last edited by MichaelP; 11-10-2008, 05:24 PM.
tip help(3/4"
hi paul i have gotten alot of help from www.contenti.com they have a easy to follow operating oxy/fuel set . also www.hoopersupply.com
and j&r welding supply has alot of info. i take a laminator and laminate them once i print them out so easy to reference but oxy/acet for 3/4" is #1 tip size cutting O2(psig) 30-35 cutting O2(scfh) 80-85 acetylene (scfh) 8/13. But remember NEVER to go over 15psi on acetylene... 1/8"-000 tip w/ 20-25 cutting oxy. 1/4"-00 tip cut oxy at 20-25psi
3/8"-0 tip 25-30 cutting oxy 1/2"-0 tip with 30-35 psi cut oxygen. hope that helps.
