Cobra/Henrob O/A torch kit
  • Cobra/Henrob O/A torch kit
    Hi,
    Have any of you used the Cobra (now I believe it's marketed under the Henrob name) torch, which is commonly marketed at car shows and swap meets? It seems to be pretty impressive, especially in making fine cuts, as well as welding at low pressure. How does it stack up against any of the other standard torches?
    Thanks in advance!
    JM
    "Search" is your friend...
    http://www.hobartwelders.com/weldtal...ad.php?t=26846
    http://www.hobartwelders.com/weldtal...ad.php?t=26489
    http://www.hobartwelders.com/weldtal...ad.php?t=25606
    http://www.hobartwelders.com/weldtal...ad.php?t=24911
    http://www.hobartwelders.com/weldtal...ad.php?t=16878
    http://www.hobartwelders.com/weldtal...ad.php?t=12811
    http://www.hobartwelders.com/weldtal...ead.php?t=8021
    And so on...
    Hobart HH 125EZ
      You beat me to it. We seem to have a lot of new members who may not know we have a great search function here, as opposed to some boards I am on where it doesn't seem to work so well.
      Lincoln 175HD
      Miller Thunderbolt AC/DC
        Sorry Guys,
        I tried the "site search" at the top of the tool bar (where it says HOBART) several times before posting my message, and it replied with no matches. I didn't realize there was another search link right below (on line with "WELD TALK"). I see now that that's the one I should have tried. Sorry to cause such regurgitation.
        JM
          JM,
          Welcome aboard.
          I don't think anybody puked. Simple question, simple answer! If you decide to go there, I'd be interested in your opinion of the unit.
          Hank
          ...from the Gadget Garage
          MM 210 w/3035, BWE
          HH 210 w/DP 3035
          TA185TSW
            Don't take it the wrong way, jmmm... just wanted to point you toward a pretty thorough discussion base here on the subject of Henrobs. I can see how the "site search" would be confusing if you didn't see the separate forum search box, too. Welcome aboard.
            Hobart HH 125EZ
              Sorry Guys,
              JM
              As already posted, please don't take it the wrong way. It wasn't meant that way. We often get the same question here many many times, and its just easier to either point new people to an old post, or try as gently as we to point them to the search function. I can see your confusion though, since there are two search buttons.
              Lincoln 175HD
                Hi,
                Thanks in advance!
                JM
                JM,
                Its well made, but nothing special. In fact the cutting can be done just as easily, and cleanly using the conventional cutting torch and the correct size tip. The low pressure bit is a GAG. A good aircraft size setup will do just as nice of a job, and weigh 1/6 what the henrob does, plus be able to get into tight places.
                -Aaron
                "Better Metalworking Through Research"
                Miller Dynasty 300DX
                Miller Dynasty 200DX
                Miller Spectrum 375 extreme
                Miller Millermatic Passport
                Smith, Meco, Harris, Victor, Prest-o-lite, Marquette and even a Dillon O/A torch
                  Thanks! No offense taken--I appreciate the guidance and the links, which I have checked out. And thanks for your thoughts as well.
                  Although I don't enter the discussion very often, I've been checking this board quite regularly and have learned a ton of stuff from the members. I appreciate that very much.
                  Yours,
                  Jim
                    Richard Finch, Author of Welder's Handbook says that it excels at cutting thin material (sheet metal, etc), and due to the way it works, creates less heat affected zones around the kerf, so less warpage on thin material.
