hobart 140 wire kinking
  • hobart 140 wire kinking
    New 8/17/22 Hobart 140. 4 times wire fed and after 1-2 feet wire kinks before entering liner. i have wire in the gas less .030 in kurled groove . correct or wrong. pressure set @ 2 per manual. what am i missing
    Suggest you pull gun lead out of feeder and try a manual feed of wire down liner to see if there is some sort of obstruction in the liner....
    You may have obstructed or damaged liner....
      At present. Wire feeds to nozzle. After flash of starting weld. Kinks @ beginning of feed to liner. Now wire trapped in liner. Really pissed off @ quality. Pressure set @ 1 1/2 > 2. Speed @ 1. Really not happy at all. Hobart contacted they r sending replacement liner ,i'll believe it when delivered,
        Not sure what you are stating of a speed @1 ... Voltage (heat) is 1 thru 4 for older models and 1 through 5 for the new model... Wire speeds seems to go for 0 to 100, my140 always seem to have a wire speed of about 50 (+/-)....
        Did you actually setup machine by door chart for "ball park" setting for wire type and material type and thickness?
