Feed Problem with Lincoln Wire
  • Feed Problem with Lincoln Wire
    Hi Folks,
    Anyone ever have feed issues using Lincoln wire in a Hobart 187 ? Our Tractor Supply was out of Hobart .035 Flux-Cored wire so I stopped at Home Depot where they had the Lincoln 035 Flux-Cored wire.
    I can not get the correct tension using the Lincoln wire. If I max out the tension, the wire will feed ok for a bit - then slip. If I back off the Max tension a little, the wheel will spin.
    This is the first time I’ve used .035, I’ve used .030 before without issues [ both Flux and non-Flux] but only Hobart wire.
    Anyone seen this before? Thanks.
    What groove or size drive roller are you using (smooth or serrated) ... In proper groove?
    Might also be a liner issue, or contact tip, did you go up to correct size...
      My Millers and Hobarts (and Lincolns) have run more Lincoln Innershield brand wire than all other flux-cored wires combined, and most of it came from Home Depot. Most of it was .035".
        The machine came with a Smooth Groove Drive Roller which is what I’m using. I’m using the .030/.035 Groove. Mine only has two Grooves [0.24 and 0.30/0.35].
        I noticed that Hobart sells a replacement VK-Groove Drive Roll [Knurled Groove] but doesn’t specify my machine [HH-187]. Not sure where to buy one though.... don’t see them sold online or through a dealer near me [New England] or what they cost.
          Not sure about you HH187 but Hobart seems to use very similar design rollers in all their machines....
          Simple search says its available under part number 261157....
          https://www.amazon.com/Hobart-261157.../dp/B00Q1AP0B2
          https://store.cyberweld.com/miqusedrro26.html
          https://www.weldersupply.com/P/2166/...riveRoll261157
          https://www.millerwelds.com/consumab...ve-roll-261157
            I've never used the knurled rollers for FC wire in my small machines, but I do acknowledge they are recommended.
              For the smaller diameter wires it isn't usually needed, I would say you will probably need it for .035 flux-core to get consistent results
                I think I found the correct Drive Roller for the HH-187. It’s appears to be a Miller part [202926] which is interchangeable with the Hobart. Amazon lists it as a Hobart even though it has the Miller logo stamped on it. In fact, my HH-187 came with a Drive Roller that has the Miller logo stamped on it. It also came with Miller Gun.... says Miller on the handle.
                A local welding supplier was willing to order the Miller Roller for me, should have it in a couple of days. Picked up a 5lb spool of .035 Flux-cored from Tractor Supply today... I’m ready to start welding again.
                  Seems to me it could be a liner or contact tip issue or maybe the liner was for .030 only.
