Hobart 140 Cut-off delay
  • Hobart 140 Cut-off delay
    On my 140 there has developed a delay in current being cut-off to the wire. When I release the trigger the wire feed stops fine....but the current continues in the wire for a few seconds. The "click" indicating shut-off is delayed by 1 to 5 seconds. I have tapped the gun to see if it is a problem in the trigger but it doesn't help. What could be getting stuck that is causing the delay?
    If the wire stops, the trigger is working. There is a contactor in the machine that is a big spring-loaded switch for the welding current, but if the contacts become pitted, they can stick.
      Ditto...
        Thanks for the prompt response. Can these contacts be cleaned or must they be replaced? Is the switch contacts visible or are they inside a unit of some sort?
          Never mind, located it...called the Contactor, will order a replacement. Thanks again for the advice!
            Ok, I'm back....where can I find a Contactor for the 140? So far I've not been about to find one on the wonderful web.
              UMmmmm
              https://www.hobartwelders.com/files/...67B_PT_HOB.pdf
              Part #44....
              https://www.millerserviceparts.com/P...roductId=10026
              https://www.airgas.com/p/MIL217584
              https://weldfabulous.com/miller-2175...1p-24vac-coil/
              https://www.ebay.com/c/1538309138
              Hobart & Miller are sister companies, they share many of the same part numbers...
                Wait, so it's only a 25A contactor?
                In that case, go to Amazon and buy one for $10. I use these every day in the HVAC repair world.
                https://smile.amazon.com/Carrier-Rep...3021433&sr=8-7
