120 or 135
  • 120 or 135
    Ok I have been offered a 120 for $150 needs new regulator or a 135 for $175 hose and regulator unknown what would be the better option?
    The 135 if you want my opinion for the better option.
      Btw this will be my first mig that isn't just flux core and I can only run normal house power and only weld up to 1/8"
        Alway buy biggest machine you can afford....
          Both cover roughly the same out amperage range. The 120 outputs more than 120 amps. The 120 is the more robust build unit. However, if I am remember correctly, purchasing consumables for the gun on the 120 is difficult to impossible. If I am remember correctly some type of conversion kit is needed. The 135 is notorious for certain components on the control board failing.
            Ok ended up buying a Hobart auto-arc 130 with Hobart cart it was only used 3 times came with hose and the regulator.
              @ $200 so not to bad used it to make the start of a welding table
                Looks good.
                Ed Conley
                Screaming Broccoli, Inc
                MM252
                MM211
                TA185
                SO 2020 Bender
                Miller 125c Plasma
