Trouble with miller 12vs and 325 trailblazer
  • Trouble with miller 12vs and 325 trailblazer
    Hi all, am trying to get ready to hit the road, no experience with a 12vs before but trying to get it to work as it is more efficient? then stick.
    Plugged everything in as miller recommends, problem is suitcase is trying to put out 60 or 65 volts no matter where I set the trailblazer.
    any help appreciated!
    Mason
    Set your trailblazer to cv mode. Set the volts on the trailblazer. Hook your ground clamp and voltage sensing wire to your work. Electrode lead to the feeder. Set wire feed speed on the feeder. Set up shielding gas if your running dual shield wire. Purge the gas line and gun. Pull the trigger and start welding.
    Lincoln Idealarc 250
    Miller Bobcat 250
    Thermal arc Hefty 2 feeder
    Thermal Dynamics Cusmaster 52
    Torchmate CNC Table
      Originally posted by 6805eagleguy View Post
      ... suitcase is trying to put out 60 or 65 volts no matter where I set the trailblazer...
      How are you measuring this and at what point in time?
        When the trailblazer is idling the suitcase digital display reads anything from 60 volts to 95 volts. The suitcase will almost kill the trailblazer because the trailblazer will only put out 35 v. Trying to put out 60 volts does not work on the trailblazer end.
          I had it working a couple days ago but am trying to work today and it is not working at all
            You can only tell the arc volts shown on the feeder while your welding. You would have to have someone else read it for you while your welding.
            Miller Bobcat 250
            Torchmate CNC Table
              Sounds like the feeder is just showing open voltage. Were you in CV mode on the Trailblazer and did you have the suitcase also set for CV mode? The suitcase won't harm the Trailblazer unless there was some massive, direct short inside the thing. You would know that in a hurry.....
              fence and gate shop worker
              At home...
              Lincoln Power MIG 180....
                Finally got it to work on a different trailblazer.
                pounded out 60 lbs of wire.
                Thanks for the Help!
