Hobart Handler 175 Feed Motor
  • Hobart Handler 175 Feed Motor
    The feed motor on my HH175 died. I ordered the original replacement PN 202 708. It is different than my original. It has a totally different mechanism for installing the feed roll. My original had a key and a screw holding the roller on. So now it looks like I have to order a feed roll. My manual shows PN 202 925 but what will I get? The new style or my original feed roll. Just a little bit frustrated right now. Should have been welding this weekend. Not happening now. Does anyone have any insight to this scenario? Thanks in advance.
    The roll you need is 202925 to be able to run .023-.030/.035 wire. This may not be of much consolation, but the the older motor 193187 would have be more money than going with the newer motor and the feed roll.
      Thank you so much. I ordered one from Amazon and may have it tomorrow.
        The Handler 175 is notorious for a few component failures on the control board that cause the drive motor not to function, so I hope you've done some troubleshooting to guarantee that the motor has failed.
          I have a 135 that I think the feed motor is out on. What is the newer part number for the motor? What other things should be troubleshot?
            Think motor is 16 volt DC try it with 12 volt battery, if it runs problem is elsewhere... Just get polarity right when reconnecting, or it will not feed wire...
            Maybe...
            http://www.brweldingsupplies.com/mil...16vdc-w-leads/
              Alec, as stated earlier the newer style is cheaper. Just get the 202708. If your roller is attached with a screw through the center then get the roller 202925 as well. To make sure it is the motor, check the DC voltage from the board to the motor, be sure to leave the motor plugged in to test.If the voltage drops off then the trouble is in the board.
