210 mvp
  • 210 mvp
    CAN THIS BE RUN ON A GENERATOR 240V-18.3A, NEMA L14-30? If so do you have that plug conversion?
    Yes (an no) IF genney only has 18 amp (about 4500watts) output you probably won't be able to run 210MVP at full output... You really want something in the 7500 watt range if you are going to run at step 7... If you stay lower than step 7 you might get by with the 18 amp (4500 watt) output generator .... It's usually recommended that a generator have output about 50% more than welder requires so generator does not bog down when you create surge on generator when you strike arc....
    Yes they make a L14-30P (four prong-twist lock) to 6-50R adapter....
    One of many sources, shop wisely for price....
    https://www.amazon.com/AC-WORKS-Adap...+14-50+adapter
    If you don't need full output of the 210MPV just run it on 120 Volts and it is equal to a HH140...
