Handler 125 MIG gas conversion
  • Handler 125 MIG gas conversion
    The Handler 125 was available in a version that was not MIG-ready; it did not have the parts that allowed shielding gas to be used. Hobart sold a conversion kit, part number 195158 that had the necessary parts. This kit is no longer available but the parts can be purchased separately. The information below is from another welder who obtained the part numbers from the HH 125 manual. Before taking this as gospel for your machine, look in your manual and match the part numbers here to what is printed for your particular machine. You can find the manual for your version here: http://www.hobartwelders.com/service/owners-manuals/
    The prices are from: http://miller4less.com/index.php
    The part numbers and descriptions are:
    137761 NUT, 750 NPT 1.31HEX .27H NYL BLK $1.99 each Qty. 1 required
    209905 ADAPTER,GAS HOSE $14.31 each Qty. 1 required
    209907 TUBING,PVC .187 ID X .312 OD X 6.000 CLEAR $2.56 each Qty. 1 required
    216397 VALVE, 115VAC 2WAY CUSTOM PORT 1/8 ORF W/FRICT T $55.42 each Qty. 1 required
    CanoeCruiser
    Harris dual-stage O/A
    Lincoln AC/DC buzzbox
    Hobart IronMan 210
    Lincoln PowerMig 135
    Miller 3035 spoolgun
    Thermal Arc 185
    Thermadyne Cutmaster 52
    I bought mine from Grainger as a complete kit. It's been a while so I don't know the part number or anything. Sorry.
      Home Depot still carries the Kit for $184 under the Lincoln Branding...
      The Lincoln Electric MIG Conversion Kit with 1/4 in. Regulator with Gauge includes everything you need (except the CO2 cylinders) to convert a flux-cored welder into a MIG welder.
      Use to covert flux-cored welder to a MIG welder
      15 psi working pressure, 20 psi maximum inlet pressure
      Includes two .025 (0.6mm) contact tips, gas nozzle, 2 lb. spool of .025 SuperArc L-56 mild-steel MIG wire, gas regulator for Argon and Argon-blend gases, adapter for CO2 cylinders, 115-volt gas solenoid, hoses, connectors and instructions
      CO2 cylinders not included
      See:
      https://www.homedepot.com/p/Lincoln-...hoC2DcQAvD_BwE
      You can do it if it becomes I can do it if you just try.
        See:
        BUT its for Lincoln..... Lincoln is not Hobart.... IT may not be same form factor in connections and voltages and such.... Probably best to stay with HOBART conversion kit for HOBART welder....
