extending the work lead on a MVP 220
  • extending the work lead on a MVP 220
    How do I extend the work lead on my MVP210?? I need ~ 40-50 more feet.......
    Why would you need to extend the work lead 40- 50 feet when the gun lead is only 10'? Extending the work lead that long is going to result in a significant voltage drop that is going to reduce the level of top end power available. Understand with short circuit transfer or self shielded fluxcore a drop in the output voltage as small as one volt is actually significant. Even a change of 1/2 volt on the output could require you to use the next tap up or it could make the tap perform better.
      The only thing you should really extend is the power cord. Just buy some SO cord, plug and recepticle and you are in business.
      Walker
      Ironwood Artistic
        Thanks......done......wasn't sure which end to extend
