Hh 210 mvp
  • Hh 210 mvp
    Playing with taps 3 & 4 on the 210 MVP Friday evening, I discovered that if I added an additional 10' to the work lead, it provided enough voltage drop to basically give me another tap selection between 2 and 3, and 3 and 4.
    May I ask where you added the 10 ft (in/at cabinet connection or was it ground lead side) and what gauge wire you used....
      Dale,
      I just borrowed the work lead from my PM 180C. I attached the work clamp of the 210 MVP to the lug end of the PM 180C lead. Then I attached the work clamp of the PM 180C lead to the piece I was welding on. Both leads are 6 ga. wire.
