anyone ever use wire cleaning pads.....?
  • anyone ever use wire cleaning pads.....?
    hello to all,
    just wondering if anyone has used the little cleaning pads that you out inside the welder to wipe off the wire before it goes through the liner. it comes with a bottle of cleaner/lube and is supposed to cut down on friction as well. just wondering if it was a good idea to use this or is it bunk.... thanks
    HH 190
    Originally posted by Lang View Post
    hello to all,
    Never had to, even in a dirty shop, with reasonable vacuuming of machines about once a month.
      Lincoln says, don't use it. I don't.
      *** Disclaimer ***
        I always wanted to try it but never did.
          I just use a square of (brown) scotchbrite pad an binder clip to keep it over wire...
            what I like using best in a shop environment is old fashioned foam ear plugs!! just run the wire through an ear plug... a lot less resistance and work's great...
