HH190 breaker sizing
  • HH190 breaker sizing
    Hi, new to the forum. Am about to buy a HH190, and want to have what I need on hand to install new 240v run. It shows the "generator size" of like 5660 watts. A quick calculation gives me 5660 watts @ 240v = about 24 amps. So are you 190 users on a 30 amp 240 v breaker?
    Welcome to the forum aboutlastnite.
    You should be good to go.
    Lincoln A/C 225
    Everlast PA 200
      This document on page 16....
      http://www.hobartwelders.com/om/6digit/o260273c_hob.pdf
      States normal input at 20.5 amps and recommends a "normal" fuse at 30 amp.... So yes 30 amp circuit should be sufficient...
      Document also state welder uses NEMA 6-50 plug/receptacle combination....
        Cool, thanks fellas.
          It can be used with breakers 30 to 50 provided the wire is 12 or better. They are designed to run on common welder circuits to 50A
            A tailor made circuit for them is a 10/30. They run fine on a 12 but I figure a small machine needs all the help it can get and you can run a buzzer on the same wire with a breaker change if needed.
              190 wireup
              I am using the 10/30 wireup for my handler and its running great. Very happy with the wireup.
