Handler 125 Adding Gas- What Size Tank
  • Handler 125 Adding Gas- What Size Tank
    I'm farily new to welding and recently purchased a Handler 125. I will be using the welder for small around the home projects and suspect mostly for thinner gauage materials. So far, I have done everything with .035 flux core, but would like to add gas for the lighter projects. What size tank should I be looking for? Is a 20 cu ft too small? Thanks.
    Minimum of 120 cf. The small ones are way too expensive to keep filling.
      Yes. At the recommended flow rate that is less than one hour of trigger time when you account for setting the flow rate, etc. I went with 80 cu ft of C25. I say C25 because C25 is stored as a high pressure gas so you can't feel the difference in weight between empty and full. CO2 is stored as a liquid and a full tank is a little heavier. I went with 80 cu ft because it'll still fit in my car trunk; with the safety cap on of course. These are inert shielding gases, I do not transport even the BBQ propane tank in my trunk, that's what the truck is for.
      Blacksmith
      Stickmate LX AC/DC
      Big cheap (Chinese) Anvil
      Hand cranked coal forge
      Freon bottle propane forge
      HH 210 and bottle of C25
        Thanks for replying.
